- Feb 19, 2020
- Threads
- 119
- 12,739
Just how do explain a back feeding of the PTO clutch from the ignition switch?Don't believe you problem is ignition switch related, as the PTO switch should be the disconnect for the clutch unless you have a RIO and the key switch is the wrong one and is backfeeding the clutch.
The only for clutch to receive power is via the PTO switch [which is an on/off switch] via the ignition switch.
As mention it can be a clutch failure to disengage even though its power source is removed. This is why some mowers has a damper diode in the PTO circuit.
