MyGrassHasCrabs
I have a yard full of trees and a wife that insists on a lawn, although the two are becoming more incompatible as the trees have grown over the past 25 years.
Too many leaves to mulch in-place in our yard and still have grass.
There have been many discussions and a few attempts to devise a "skirt" that surrounds the mower deck such that you'd keep the high-lift blades at the highest setting (usually 4") and it would still pick up leaves. None of the attempts I've seen have borne fruit, though, and it's still a painful process to deal with leaves every fall.
So, at this point, I have resorted to a couple of helpers. One is a leaf vacuum, such as the pull-behind Trak-Vac I have used for many years now. It sucks the leaves up through the mower deck (yes, the deck must be engaged too, so there's still spinning blades involved and either setting the cutting height lower than 4" to get all the residue) and into a spinning mulcher driven by a 9 HP B&S engine, then into a 55-gallon rubbermade drum that has to be emptied very often depending on leaf density. There is another option called a "Cyclone Rake" (https://www.cyclonerake.com/) that has gotten excellent reviews, but I've never tried it.
The second tool is one that I bought last year - I call it "The Beast" - it's the Echo PB-9010T, 220 MPH 1110 CFM blower. It's expensive (around $700) but makes (relatively) quick work out of a mountain of leaves - a real time saver, although it is a "beast" in more ways than one.
Good luck from a long-time leaf wrangler with no magic solution (so far).
