did you watch his video?Engines need spark, fuel, and air to run.
Check your spark plugs. Are they wet with gas? Do they spark?
Is it getting fuel to the carburetor?
Is the air filter clean and dry?
Is the choke linkage hooked to the throttle cable?
I did. It sounded like it was spinning just fine to me.did you watch his video?
His starter isn't engaging the flywheelI did. It sounded like it was spinning just fine to me.
I went back and looked. See my above reply. That's what I get for not using both my senses of hearing and sight together.His starter isn't engaging the flywheel
Hello sano888,Two weeks after getting the belt problem fixed, now it won't start. Thoughts?
