Locating part
Scrubcadet10
Moderator
Staff member
Husqvarna 545008096
NLA/Out of stock. No good replacements on Scamazon.
Im wondering if a Echo bushing would work, but the kicker is, the fuel filter fits right to the bushing..I guess I could remedy that with the correct size fuel line though.
HUSQVARNA 129 325 329 TRIMMERS​
545008096 supersedes to 599568901
Seems every one of my sources is out of stock.
Now can you give me the diameter of fuel tank hole. I need to check the Echo grommet here.
Scrubcadet10
Moderator
Staff member
And the Husqvarna web page doesnt pull anything up with that number
Scrubcadet10
Moderator
Staff member
Scrubcadet10
Moderator
Staff member
Wouldn't be the longest ive waited for a part... but the owner wouldn't be happy.
Im thinking, if I can't find one, or a echo won't fit, of putting some Permatex motoseal on the grommet and seeing how that does...........
Echo 13211555931 is for 13/16" hole IE .8125" [20.64mm] and 21.16mm is .833". the Echo is over .020" smaller.
Double check that the caliper is zero out.
Scrubcadet10
Moderator
Staff member
should be, i always zero it when it put i back but will re-zero and re measure
