How to tell if zero turn front tire that has a flat surface is worn?
P Paxilcr1! Forum Newbie Joined Sep 12, 2025 Threads 1 Messages 2 Sep 18, 2025 / Front tire worn! #1 How to tell if zero turn front tire that has a flat surface is worn?
S slomo Lawn Pro Joined Jul 14, 2019 Threads 81 Messages 5,888 Sep 18, 2025 / Front tire worn! #2 Paxilcr1! said: How to tell if zero turn front tire that has a flat surface is worn? Click to expand... Does it look like a new front tire? Does the new tire come with flat surfaces? Is the mega mower parked for long periods of time causing a flat spot on the tire? Post a picture of said tire on here so we can SEE what you are describing.
