steves snapper
 - Apr 20, 2025
- Threads
 - 5
 - 24
Spark plug gets gas fouled every cold start
Intek 12.5HP I mow twice a month. When I go to crank her up, I press the throttle all the way forward which is the choke (I’ve always cranked her this way) she won’t start bc the spark plug is covered in gasoline.
Should I not be choking an just leave the throttle at the position I run her at (just a bit lower than WOT probably ¾.)
I now air out these gas fouled plugs an am able to reuse on a rotation, would prefer not have to be forced to swap a plug twice a month.
Pls recommend a fix maybe turn back the carburetor a bit.thanks for advise
