Phillybo
Guess guides were good. Should have did leakdown first. Bad rings. Massive air from oil dipstickmanual say replace head if it overheats and damages guides. Ne factory kit per head is $200 - $220. What is your time worth? Or lets say you fix it, it lasts 10 hours, guide moves, a valve sticks open, takes out the piston, valve, connecting rod, scores the cylinder wall ... what then?
