Skippydiesel
- Nov 29, 2020
- Threads
- 15
- 313
Sir! You are both a gentleman & a scholar - you flatter me.
"Is this because the Cub has three mowing blades, and the John Deere has just two? What do you think?"
Speculation:
Depends on what you mean by blades.
Two cutting heads will have 4 blades (even if its a single part, each blade has two cutting edges). Three heads, 6 blades.
To give a nice even cut, the cutting arks must overlap slightly - its much easier to achieve this with three cutting heads, than with two.
Assuming the same mowing width for both mowers;
The two cutting heads blades are having to do more work on every rotation than the 3 heads.
Given the better overlap of the 3 heads, you will likly get a better more consistent finish or your lawn.
At a given speed, the three head mower is less likly to get "bogged down"
The Cub may also get away with a slightly less powerful engine.
Speculation:
