Craftman 5000 Watt Generator hard Starting when Hot
jono252525
10w-30 will shear down awful fast in an air cooled engine. Briggs, Kawisaki, Kohler and so on state multi-grade oils will be consumed more compared to a straight 30W. Meaning you will need to check it at every use. I do that anyway with all oils.
Use the oil your engine manual says to.
Your Right but I check the oil each time I use it.
Forest#2
Couple thing you might try.
First remove all loads on the gen when first starting. (and before killing the gen)
Start it up cold and then kill it before it gets warmed up and go for a re-start. Only let it run for 60-90 seconds) You are mainly checking to see if maybe the hard re-start is not all heat/hot related.
On gens engines when they are not running the governor has the throttle held at wide open. Tie the governor/carb at idle and try a re-start)
Also see if the engine idles good. This is to see if the low jet area on the carb is OK. (It's possible that it runs ok at 3600 rpm but won't idle smooth. (low jet carb issue adding to the hard start issue when hot)
You say the compression is 70. That seems low to me is concerning.
I've never checked the compression on a HM100 but I do know that normally they are very hard to pull through using a rope crank and they also want to kick back if they are not brought up on compression slowly and then pull through. I never could sense that they had a compression release.
(and even harder to hand crank in cold weather for a re-start) Hard manual cranking is main reason why I was doing converts to electric start.
Even with electric start I had to use a very good lawn tractor battery rated for around 250CCA due to the compression.
jono252525
I look at the Cam and on mine there is a release system.
Also
I did like you said adjust the pilot at ideal and the main on I speed.
The engine restart good with no choke if it is not to warm.
Ozcub
Heat sink into carburettor place a heat resistant barrier to shield carb from heat
jono252525
I will keep you posted, when I have made the modification.
Thank you.
Do you have a solid flow of fuel AT the carb inlet? Can you drain the fuel tank from/at this same location? Any reductions in flow rate while doing this? Possible tank cap vent?? Trash in the tank and lines. Fuel lines internally deteriorating, clogged filter????
I've never seen a mower engine percolate. They don't run as hot externally as say old GM land cruisers under the hood. Fuel tanks are in free air. Simple rubber hose to the carb.
Forest#2
You say it has electronic ign and you replaced the module with a generic???
If so what specs did you set the air gap?
Are you sending fresh fuel to the carb or old fuel with additives?
jono252525
I use an external tank right now
jono252525
New fuel and .010 inches gap
jono252525
I found the problem, the engine front cover on that unit as a big square old at the bottom and the
engine is suppose to have a shield that attache to the 2 engine supports and close the hole when the cover is in place. In my case the shield was missing and the cooling system was loosing all the air under the engine.
