Ryobi SS26 2-cycle weed eater upper shaft gets uncomfortably hot!
lowpost99
  • / Ryobi SS26 2-cycle weed eater upper shaft gets uncomfortably hot!
Can't figure out why the upper shaft is getting very hot around the rubber trigger grip. I can't figure out what is causing this, I've swapped upper shafts with another, but no issues until coincidently, I had the carb dialed in by a shop. The head slips a good bit clockwise on the shaft, but this hasn't ever caused a problem like the hot handle. I believe that during my shaft swap, a bushing or some other type of guide for the shaft may have fallen out near the head and now I'm getting excess friction from the rotation of the shaft. Please help!
Auto Doc's
Sounds like the power head needs to be removed, then upper drive cable needs to be taken out of the tube and a thick coat of grease applied to it. When the power head is aligned during install, the square end of the drive cable needs to fit into the drive portion of the clutch properly or it will create drive cable binding.
lowpost99
Thank you very much! I'll give it a try and update the thread ASAP !
lowpost99
Ok so I've removed the upper shaft, and I can see the drive cable, but I think it's more of a rod than a cable. Also it doesn't slide out, well at least not by hand. When searching online, for removing the drive cable on a Ryobi, I only found vids showing replacing the entire shaft as a unit. Anyone have additional ideas how to remove the cable from Ryobi shafts? Or what else may be causing this heat issue and where to address it? Would sprayin lithium grease or WD40 into seat of the head where the shaft goes hurt anything?
Auto Doc's
Does your model have the 2-piece shaft assembly that you can change out attachment on?
Here a Parts Tree link:
There shows to be a tension spring #8. Is that in place?
lowpost99
Yes, there is one down around the drive shaft/cable
