22hp Twin - governor shaft bushing placement
Not the greatest picture but may be able to blow it up and see how everything is sitting
shre74
Ok,
I have the seal "seated", now I am looking at the shaft itself "internal" where the e-clips are attached...does the shaft sit on that place-holder with a bushing or does it sit in there with no bushing?
Thank you, when I get home at 345, I'll take better pics
bentrim
From Repair Manual 273521TwinCylinderOHV
Install Governor Shaft Bushing
Lubricate new bushing and governor shaft with engine oil.
1. Assemble governor shaft to sump to act as a pilot for
bushing.
Do not install lower E-ring.
2. Using Tool #19129 press in bushing until it bottoms,
Fig. 13.
3. Install lower E-ring.
a. Install new oil seal.
Governor shaft must rotate freely.
