Seat Glue
hlw49
Anyone know of a really good glue to glue the seat cushion back on the seat pan.
I would prep the seat pan. Sand off all the old adhesive and paint. Use rough paper to allow the adhesive to get into the metal and stick. It's all about the prep work.
Auto Doc's
Hello hlw49,
Heat molded seat assemblies can be a real pain to work with.
For extreme cases, I usually rough up the plastic or sand the metal and then use expanding foam in a can with a putty knife. After that I use plenty of gorilla tape to hold it together until the foam cures. Once cured, the tape is removed.
It takes a little practice to realize how the expanding foam works and holds. That stuff does not give up once is sticks the seat materials together.
Tiger Small Engine
I use Gorilla Glue construction adhesive (white) and comes in a caulking tube. Make sure surfaces are clean, apply, clamp for 24 hours.
Make sure the glue you use, is foam safe and will not burn it away.
Auto Doc's
For whatever glue/adhesive you decide to use, read the label. Many of the foamboard adhesives have 1-week cure times.
Contact cements work great but breaks down with time and excess heat.
