eleyarms
I had a problem where my Z345 would not crank. Battery voltage was full and the hour meter was working. Day one I gave up. Read on-line suggestions. Day two, tried again and noted that when I extended the control arms I was not hearing any relay clicking. Lookin down into the left control arm well where it pivots, I noted a small wood chip that was blocking full outward extension of the arm. I removed the obstruction, heard the relay clicking and tjen started right up. Simple fix that was easily overlooked. My 2 cents.
