andy spence
- May 15, 2013
- Threads
- 1
- 13
This is something that happens a lot with these Briggs engines. I have repaired several with a way that a lot of the hard core mechanics will disagree with but add a set screw in the spot where the compression release lever rests until it starts. It is just like the camshafts were back in the day when Briggs advertised their Easy spin starting. It is just a small lump on the intake valve to release the compression when starting. Works the same as the existing lever as the set screw is rounded and only protrudes .013 of an inch so that it does not affect the running of the engine but solves the problem with the starting using a 25 cent screw and a little time since the engine has to be removed anyway. Agree or not, just food for the thought but it works for me with no complications.
