In over my head again *Updates*
Auto Doc's
Hello sano888,
A brass bristle brush is ideal for cleaning exposed switch terminals. "Polishing" them is overkill. Just expose clean brass or metal of the pins and you are good to go.
The female connector pins are tricky because they tend to spread a little over time. Usually, a fine pick tool or a jeweler's screwdriver is used to tighten them back up gently.
Some people do not realize that die electric grease in non-conductive and if the female pins are too loose, proper contact becomes questionable. People often slobber that stuff into connections to help keep moisture out and prevent future corrosion, but it will cause problems if the pins are not properly checked first.
Used a toothbrush sized brush with brass bristles on the switches. Is that a bad idea? How would one polish them? That's a new concept to me.
Bad idea not so much. Better than it was for sure what you did.
I use Mother's Mag Wheel Polish. Or Flitz is great too. There are many simple metal polishes out there. Clean the bulk of the schmoo off. Little red shop rag and a dab of polish. Rub away the tarnish. Then shine up with a rag. Make sure the contacts are solid when you put the wires back on. Should drag the legs on a fuse for example. See scratch marks on each leg. Too loose, take pliers and gently smash the terminal down. It will tighten up as you will see.
sano888
Appreciate it fellas. Idle arm was bent a bit. Flattened it back out with a BFH on the anvil vise. Idler pulley sounds rough so going to replace. Fingers crossed that it's that simple.
Should be. Keep at it. Sounds like you are making good headway on her.
sano888
So...while I wait for the pulley, I'll do some clean up and general maintenance, but the presenting problem was deck drive belt was shredding. Anything I should be paying attention to while I've got it apart?
Dead bearings and such. Listen to them while spinning each one. Any growling needs replaced.
Auto Doc's
You say "shredding" Is it physically getting chewed on by a pulley or a guard that is out of place, or is it just chunking section out of the "V" portion of the belt due to age, heat and dry rotting?
sano888
I'm not sure. I wasn't running it when it happened. All I know is that the deck drive belt has broken twice. Belt appears to be whole but snapped apart. Straightened the idler arm and am replacing the idler pulley. I won't know more until I put a new belt on and run it. Just looking for other things to check while I've got it apart from the experts on here. Deck belt seems fine. I probably would have replaced the spindles a while ago if it were mine but that will have to wait.
GearHead36
I would check the spindles, and make sure they spin freely. Grease them while you're in there. Most spindles never get greased. You will need to apply grease until it squirts out somewhere. At that point, the grease will force past the seals.
Gord Baker
Used some Lectra-motive cleaner on the grease and wire brushed the switch. Tested OK. Started right up. Now on to why it's throwing a belt. Stay tuned.
Well done. Check the belt for correct WIDTH. To narrow = too loose. Get a new one from Dealer of proper size.
Check Spindles and Idler pulleys first.
