Looks like Ohio has 431, NY has 589, NC has 612, TX has 53, and UT has 214, and IA is out of stock but that is PD's version of a Amazon warehouse with robot picking and the robot AI hasn't learned to order it's own replacement stock yet. Iowa is always the first warehouse to run out of stock, and the last warehouse to get restocked.This is all adding up to a failed compression release. Aftermarket cams are junk and genuine Briggs are on backorder the last time I had to get one.
On top of it, the starter has likely been strained repeatedly and will soon fail once the cam problem is solved.
Very well could be the compression release failed.This is all adding up to a failed compression release. Aftermarket cams are junk and genuine Briggs are on backorder the last time I had to get one.
ywHello hlw49
Thanks for that!
Doug Lee
