Raptor SD 60
Trey249
Mower was running and quit, will start occasionally for a few seconds then shut off. Was using extremely to much gas before this started. Any ideas?
Tiger Small Engine
Need more information. Model number of engine, more details in general.
Trey249
Kohler 7000 series 26 hp, thought it was bad gas but I pumped it out and put in fresh gas, before all this I could cut my yard on one tank, it now takes over 2 when it's running, takes forever to restart after it runs out of gas
First thought is hole in fuel line leaking gas and/or sucking air into the line. Second thought is to check the oil to make sure it isn't leaking into the crankcase from a faulty fuel pump. I would think if it was burning all that extra fuel it would be running rough and blowing lots of black smoke.
