What's your go-to string trimmer line brand??
davev1pa
A little-known trick about nylon trimmer line is to wet it with water before use. It's true and it works. I usually wet my loaded trimmer head before each use.
Soapy water?
hlw49
Oregon Round Gator line with aramid core. Not suppose to use cable or wire any more it can break and stick in your leg or put your eye out.
oldlawnguy
The older the better... My neighbor gave me a Stihl FS-38 two years ago cuz he went with a E(NO)-GO.
This year she started to be non cooperative. I already have a Ryobi, so finally paid some attention to it. Cracked the Zama carb cleaned it out and it needed new fuel bladder and fuel pump (both were crunchy). Zama gaskets, bladder and fuel pump kit was $4. Fired right up and humming smooth again. I too use the couple pulls on choke, then 1/2 choke, then no choke approach while throttle lock engaged.
Asked neighbor how old is the STIHL you gave me, he said I got it about 15 years ago. Also I grease the bearing on the head yearly with a grease pen.
RevB
Like trimmer line can't as well.
2stroke-RN
I have two types of line I use-
1) For Brush and large weeds, use shakespeare fluorescent yellow .110" triangular nylon line for my Stihl FS 65 that usually takes .095". I just feed through two pieces in the serpentine like labyrinth hole assemblies.
2) For pure lawn/small weed control I use Stihl branded .095" multi-faceted red nylon line.
