Dwayne Oxford
It's leaking with bowl on, but if I hold it up with bowl off it'll stop. I stretched spring, didn't help. Any fixing the accursed plastic apparatus?
Yup, 1st thing. I just need to know if anybody's figgerd an adjusting trick. When America was great we had good brass adjustable floats.Have you checked to make sure there isn't gas in the float making it sink and not stop fuel flow at the float needle. Floats on occasion leak and fill with gas.
Nah, all looks new, got a catch bowl in inlet line. Only use non ethanol(water) gas.Is the float valve rubber/Viton in good condition?
I there any fuel "varnish" , other crap, on valve tip/valve seat?
Stretched spring more, not leaking now, got new needle if it leaks again. Non adjustability is TRASH.Sounds like float is getting stuck someplace with float bowl, causing needle not to work correctly. Maybe you should just get new carb?
