Tecumseh OHV14 204009
McTurff
Have an older Ariens rider with a Tecumseh OHV 15
model #204009
Can't find valve settings anywhere for this motor
And do you set the same as a Briggs??
Thanks
Auto Doc's
Set each valve to .004 inch where feeler gauge just fits with a slight drag between the rocker tip and valve stem. Do this with engine cold and plug removed.
Page 84 has the specs page. The procedure is explained just prior.
McTurff
Thank You
