Tire sizes on a CZ 4817
GearHead36
I have a CZ 4817, and the tires are fairly old and leaky. I just deal with it by putting air in them every time I use it. I recently tried to level the deck, and found that I couldn't get the deck high enough. I set the cutting height to 3", but at the max height adjustment, the blades were lower than 3". So I'm thinking the tires may be the wrong size. By replacing the tires, I may be able to kill two birds with one stone.
What are the correct sizes?
GearHead36
Thanks, ILENGINE. The rears are right, but I'm not sure about the fronts. They are currently Kenda Corsas, and size printed on the sidewall is 4.10/3.5-5. I don't understand that sizing. 4.10/3.5-5? What is that? And is it the same as 11x4-5?
Honest Abe
are you saying your machine is a "Husqvarna CZ4817"... ?
if so -
Detailed Specifications:
  • Engine: 17 HP Kawasaki V-twin engine with electric start.
  • Cutting Width: 48 inches.
  • Transmission: Dual Hydro-gear BDP10A pumps and Parker-Ross TE14 wheel motors.
  • Tires: 13-inch front tires, 23-inch rear tires.
  • Fuel Tank: Twin 5.7-gallon saddle fuel tanks.
  • Seat: 18-inch high-back seat with armrests.
  • Discharge: Side discharge.
  • Productivity: 3.8 acres/hr.
  • Other Features: Beverage holder, commercial-grade transmission and deck.
  • Accessories: Low-mounted headlight kit and trailer hitch are available.
  • Model: CZ4817, also identified as 968999220.
GearHead36
This is the Husqvarna forum, so... yeah.
Those specs don't match my machine. They must have made a change at some point. Mine has a single cyl Kohler Command Pro, and only one fuel tank.
GearHead36
Here is a photo of the ID sticker. I guess that COULD be 968 99 92 20.
