Tiger Cat will not start after mowing all day;Tiger Eye problem?
estebank
  • / Tiger Cat will not start after mowing all day;Tiger Eye problem?
I have a 2021 Tiger Cat with 142 hours. I used it to mow for 4 hours with no problems. After blowing the dirt off with my leaf blower the mower will not start. All safeties show satisfied on the Tiger Eye but when the key is turned the Tiger Eye just makes a clicking noise and the starter does not engage. I'm guessing it is the $350 Tiger Eye module which is most likely not under warranty any longer
estebank
Hey thanks for the help everyone (sic).
I found the issue and fixed it. If anyone is interested, I will post the solution but it seems this issue is of not much interest to anyone.
JGGMC
what was it?
You got to realize not everyone works on everything. For example I only have three Scag SST61 under my wing and it been most deck problems. Most likely no one here has had that problem. Personally I am not going to guess at a solution.
Filled the tank, with gas?
MParr
Post the solution!
JGGMC
that clicking noise is a low battery
estebank
So sorry everyone! I got to mowing and forgot to reply. Getting older hasn't helped my memory.
The solution....replaced the old battery. I guess there was just enough juice left to start one last time and run the mower. So, when your tiger eye starts winking at you, pay attention.
It is hard to see the forest sometimes because all of the trees keep getting in the way.
Its Me
estebank​
don't want to be rude to you but you posted this (I found the issue and fixed it. If anyone is interested, I will post the solution, but it seems this issue is of not much interest to anyone.) why would no one be interested anymore as you said, I thought this Form was about question, answers, suggestions on repairs and explaining what the problems was, Joe​
