Using more than normal gas
Miles1
I put new fuel line on when putting on new carburetor, also a new filter. Top of engine is clean. Thanks for trying to help. I don’t see it leaking gas anywhere.
If you have a fuel line connection with no clamp/s, fuel can slowly leak out and show no signs of leaking.
Had a mower couldn't figure out where all the gas was going. Replaced fuel line and added clamps. Stopped that issue. Would top it off after mowing. Next mow she would be either dead empty or close to.
Miles1
Thanks I am going to check the fuel lines. I did put a filter on a new fuel line coming from gas tank. I don’t think I put clamp on hose out of tank. It fit tight so I skipped that. I guess that may have been stupid on my part.
