neighborbill
I am having a weird problem which should be simple to fix but its' not.
Starting the Kubota (trying to start) sometimes yes some times no.
A couple of years ago I replaced the starter motor and the attached solenoid. Not long after, the problem started up again. Click! but no start. Click! and it starts. I replaced the solenoid because the starter motor would spin when I jumped it but the solenoid wasn't kicking in, even with the 12 volts applied to it. Worked for about a year. Now it is doing the same thing again, so I replaced solenoid again. Worked again until now. Click! Click! Start!
I tore apart the last solenoid and the contacts were just fine. That wasn't the problem, so I assumed it must have been the coil.
I also replaced the starter switch. That's not the problem either.
Why is this happening. This shouldn't be so complicated.
I'm wondering if the solenoids were OK and something else is giving me this problem. What could it be?
