Repairs Ariens 93605300/a22h46 motion control lever adjustment question.
GaryTroy
  • / Ariens 93605300/a22h46 motion control lever adjustment question.
As stated, I have an Ariens model 93605300/a22h46 ride on mower. The motion control lever is soo loose that I have to keep my hand on it to use the unit. If I don't, it will back off almost to the neutral position on its own. Can anyone tell me where should I make any adjustments to tighten this lever? Thanks in advance for any help offered.
GaryTroy
Bump for help.
Well no one is going to answer this I see.
Tuff Torq K46BA Transaxle.
Provided that the fiction pack is not worn adjust 101 nut a little tighter. If fiction pack is worn then you need 19216829770 [109] kit from Tuff Torq part supplier. It just two fiction washers. Should be able to change the washers without driving one or two pins [58, 96] if you are good.
Hmm only took 6 tries and 20 minutes to post.
GaryTroy
Thank you so much. Ill get on ot ASAP
