Ive managed to kill three Ryobi strimmers. They get harder and harder to start and then a compression test shows lack of compression. Sometimes you can see the piston is scored. Not sure why as I use fuel filters and the right amount of oil. Someone once suggested its important to let them warm up before use or you can get micro seizures?
Anyway I think normal is 90-110psi with a minimum of 70psi so yours is a bit low. Thing is once mine started they tended to keep running so not 100% convinced thats it. Check the anti spark mesh on the exhaust as others have suggested.
