Mowerflipperguy
So here’s the deal. 2019 Briggs 33R777 0012 G1 fires right up every time. Runs rough and pops at high rpm (although it won’t get nearly as high as it should) but runs smooth at low RPM. I’ve both cleaned the OEM carb and replaced the carb, same issue. Valve clearance is good on intake & exhaust. Fuel is fresh. Flywheel key is in place. Magneto was swapped. In the video you can see a disconnected plug but that doesn’t change anything. Oil is new and at the right level. Valves bounce on each rotation (good cam). Choke moves freely (video shows this). Linkage is not restricted. All checks/adjustments made zero change to how it runs. Video link below. Any ideas?
