RZ4623 will not stay running
ACF
have a husqvarna rz4623 model 967009801 00, mower starts up and runs when you take brake off it dies, the control arms in the outward position with safety switches depressed, replaced brake switch did not solve problem, seat switch is bypassed, with control arms moved inward the mower will not start thus assuming that they are working, any suggestion will be a great help thanks
IF jumping the seat switch connector, Don't. And unplugging the connector won't either as it contains a shorting strip. Otherwords the seat switch has to be connected and depress in order to bypass the circuit. IE the seat switch is an open circuit whenever to operator is present or the seat switch is fully depressed. And I have seen connector shorting strips to go bad and short the seat switch all the time or the connector when plugged in might not depressing the shorting strip enough and it still shorting the connector.
ACF
removed shorting strip runs now
Auto Doc's
Hello ACF,
It is never a good thing to jumper any safety device. Manufacturers are intentionally making the wiring more complex to prevent people from doing it. "Accidents don't happen on purpose".
ACF
true
