How do I tell which LMT Walbro that I have for parts selection?
GAJoe
  • / How do I tell which LMT Walbro that I have for parts selection?
So I go to a small engine parts website and put my engine Model and Type (286707-4029-01) in to order, new imulsion tube. I click on the Carburetor drawing and it brings up a page of exploded parts drawings that include a Nikki at the top and a Walbro at the bottom. The walbro has a 125 in the upper left corner that I select. And that opens a window that shows options for "Gravity Feed" and "Pump Feed" with "Gravity Feed Part # 498027 Unavailable" selected. The window shows exploded drawings for Nikki at the top and Walbro at the bottom. I choose the Carburetor Nozzle (# 142) and a window opens up showing a list of LMT and #'s to select from.ImTubeOptions.jpg
When I select one by clicking to fill the dot, then the nozzle Part# and availability is shown.
I assume that my origional Walbro carb is the B&S # 498027. I don't see any such number on the carb. Which LMT do I select based on what I find on the carb that I have in hand? The following pictures are all of the numbers that are found on the carb.
IMG_0783-DeNoiseAI-standard.JPG IMG_0784-DeNoiseAI-standard.JPG IMG_0786-DeNoiseAI-standard.JPG
IMG_0787-DeNoiseAI-standard.JPG IMG_0789-DeNoiseAI-standard.JPG IMG_0790-DeNoiseAI-standard.JPG
Thanks for your help!
Going to try to post.
LMT-77
I would assume it is the 697592 nozzle as LMT is not list otherwise.
Walbro says the Carb is Briggs PN 497082 but I am unable to find any listing for it on the Briggs Dealer site. Briggs order as a base carb and modified it and gave it a new PN.
Edit: my lord it actually posted.
GAJoe
LMT-77
Thanks for the reply. I know that it took patience. I was wondering if it was my ISP.
HawkeyeChuck
If your existing 498027 carburetor is structurally sound but suffering from wear or clogging, the Briggs & Stratton 498260 Overhaul Kit is a smart option.
