Sealed hydrostatic transmission
shurguywutt
Do you think it would be possible suck the oil out on 2200s. Or do you have to remove them.
Most definitely. The 2100s and the 2200s are pretty much the same transaxles. Just be sure to get them hot first so the oil is easier to suck out. Also be sure to put the same amount in that you take out. Once done, do the air purge procedure that is in the manual. Do this by putting the axles in neutral and running them foward and reverse for a few seconds about 20 times. Try your best to keep everything clean and not introduce dirt into the system.
Nuclear
Most definitely. The 2100s and the 2200s are pretty much the same transaxles. Just be sure to get them hot first so the oil is easier to suck out. Also be sure to put the same amount in that you take out. Once done, do the air purge procedure that is in the manual. Do this by putting the axles in neutral and running them foward and reverse for a few seconds about 20 times. Try your best to keepT everything clean and not introduce dirt into the system.
Nuclear
Th
Thank you. The fill hole in a 2017 Hustler Raptor Limited to pretty hard to get to but I'm going to try to get it changed.
shurguywutt
You can try using an 'oil syringe' that you can get off amazon for ~$10 which might make it easier.
Nuclear
Thank you.
Nuclear
using the syringe I've only been able to get 22oz out of the unit, seems to be no way to get the 1/4 hose any deeper. Any idea what I could try?
shurguywutt
22oz is fine, its almost half the volume. I am usually able to remove closer to 28 oz. I just do the partial drain and fill with fresh as periodic maintenance. Takes about 30 minutes after you have done it a few times.
