jes_in_sac
- Sep 7, 2024
- 24
Definitely not the 50A setting which is supposedly for starting, although I've never seen one be able to start anything but a lawnmower or motorcycle sized engine. Most chargers will have an automatic charging circuit, unless it's very old and very basic. So whether you do a 10A fast charge, or a 2A slow charge, when the battery is fully charged, the charger should shut the primary charging current off charging mode and go to a maintenance mode. Under normal circumstances, the 2A low amp slow charge is best for the battery, and use the 10A fast charge if you found your battery dead or ran it down trying to get the engine running and it wouldn't start for whatever reason, and need to use the mower and give it a few minutes at fast charge to put just enough juice in it to start it up, or work on the engine again to try to get it running.
