GearHead36
- Apr 26, 2023
- 451
Recently, I decided to do some deck maintenance on my Cub Cadet Pro Z 100. Two of the spindles (p/n 918-07255) seemed pretty solid. No play in any direction. Before greasing, though, they made a bit of noise when turning the blades. After greasing, they got quiet. The 3rd spindle... had vertical and lateral play. I figure that it's toast, so I ordered a new one. I figure that the housing is worn. Even if it's not, it's not a bad idea to have a spare. But a spindle is just over $150. Yikes! So I want to make sure the other two last.
I've been greasing them every year, but I wasn't getting enough grease in there. This time, I put in grease until it started coming out, and it came out through the bearings. I'm sure that the bearings have grease now. At least, on the good spindles. I didn't see a need to waste grease on the bad one.
The bearings on the "good" spindles got quiet once they got filled with grease, but not before that. Should I replace them? If so, how do I determine the p/n for the bearings I need?
The bearings are not sealed. The spindles have seals that must come out to be able to remove the bearings. See photo.
There's one on the other end of the spindle, too. Can they be removed without damage? I tried prying on them, but couldn't get one out. I was afraid to pry any harder. Are the seals available separately? If so... p/n?
BTW, the mower has about 400 hrs on it. I suspect the spindles do too, but I bought it used, so I can't be sure.
