Gord Baker
 - Aug 21, 2018
- Threads
 - 1
 - 486
Your description indicates that it is running in a lean condition.  Try giving it a small bit of Choke. If that cures it, then you need a carb /cleanout/rebuild, perhaps opening up the main jet beneath the Emulsion Tube a tiny bit.  Remove hose at filter and Run some Carb Cleaner directly into the fuel line.
