- Sep 7, 2024
- 3,393
A 90-120 gear oil would do the job. Much of it depends on the age of the seals. If it seeps, keep it topped off and monitor the level every few weeks.
Thank you . I'm not sure what the service technician used before for lubricating the chain case . I popped open the stopper thing and it the lubricant inside seemed like greese consistency .A 90-120 gear oil would do the job. Much of it depends on the age of the seals. If it seeps, keep it topped off and monitor the level every few weeks.
You want 00 grade grease. Typical car bearing grease is NGLI #2. It is way thicker than 00. Use 00 in the rear diff and chain case. 00 has a consistency of pudding. Do not use any other type of gear lube or 80w-90.Thank you . I'm not sure what the service technician used before for lubricating the chain case . I popped open the stopper thing and it the lubricant inside seemed like greese consistency .
Can i just add the 90-120 oil to it . or should i drain the old lubricant and fill it with the 90-120 oil . Thank you for responding
You want 00 grade grease.A 90-120 gear oil would do the job. Much of it depends on the age of the seals. If it seeps, keep it topped off and monitor the level every few weeks.
1.Open the vent on top of the gas cap when mowing.It runs fine for about 15–20 minutes, then starts to stutter and shuts off. When I check, the fuel filter is dry. After letting it sit for 10 mins, the filter fills up again and it starts right up — but only runs for another 15 minutes before doing the same thing.
No. Fuel level and tank are higher than carb inlet nipple.The fuel filter is mounted lower than the carb, and the fuel line is a bit long. Could this be a gravity flow issue?
Yes, with a good NGK plug for that engine. If she measures over 5k Ohms, she is counterfeit. Take a meter to your auto parts store and test prior to buying the plug. That plug you show is some Chinese no name junker. Replace it ASAP.Also, I pulled the spark plug — it looks dark and sooty (pic attached). Should I replace it?
You can but that is not what Snapper used.Can i just add the 90-120 oil to it .
No.or should i drain the old lubricant and fill it with the 90-120 oil
Perfect. What about the rear differential? Needs some 00 grease too. Jim Jackson on youtube has many videos on these machines.added 00 grease for the chain case
So the wrong fuel filter sounds like it was the root cause of the stopping issue. Thanks for the update.1) Replaced the fuel filter with the red one and the mower ran fine , no stopping at all .
