That deck is clean compared to some of the decks and mowers that come through my shop every year.Thanks. I suspected the shields were there because of a legal requirement. I'm guessing it didn't apply to the UK in 2008 when I bought a new Craftsman LT2000 (US made).
However, I was disappointed to find so much debris had accumulated behind the shields. I now realise the regular hosing down wasn't reaching behind the shields. Something for me to think about in future.
BTW, the slipping belt was due to one of the pulley brakes being stuck and not releasing due to corrosion. Fixed with a bit of lubrication and luckily the belt is still good.
PS. "Palaver" - $2!! You've been robbed!! It's free in the UK.
Some of the decks on top, and bottom that get serviced by me are absolutely packed. To the point where I charge extra. To the point where it should be embarrassing to the customer, but it isn’t.That deck is clean compared to some of the decks and mowers that come through my shop every year.
Someone removed the shields off my 80 year old aunt’s zero turn. She wasn’t thinking, reached down to remove some debris from the deck while mowing and now has one less finger. True story!Just leave the shields off so you can hose the deck off. The decomposing grass buildup can cause the deck to rust.
You’re right! I believe the collection of grass debris on the deck is what caused the pulley brake to seize. There were other signs of corrosion too: springs, deck steel etc. and this is a machine that is less than 2 years old and has never been stored outside.Just leave the shields off so you can hose the deck off. The decomposing grass buildup can cause the deck to rust
Sorry to read that. Clearing a rotating deck is risky; I‘ve never done it.Someone removed the shields off my 80 year old aunt’s zero turn. She wasn’t thinking, reached down to remove some debris from the deck while mowing and now has one less finger. True story!
