Bmwz3coupe
I have a briggs motor on a power washer that is acting up . I can pull start the motor and do a project then shut it down. When I go to restart the motor the pull cord will not budge. I pull the recoil mechanism off and the pull cord pull nice and smooth. If I try to rotate the flywheel with my hands it will not move. If I use a socket wrench to turn the flywheel it will not move one direction but with a little effort it will go the opposite direction and then back the other direction smooth as can be. I reattach the recoil unit and the motor fires right up and I can continue my project until the next time stop and the problem starts all over again.
