- Sep 7, 2024
- Threads
- 19
- 1,699
I cannot explain the why. I can only say what was done and how it was fixed. The only explaination I can think of was the plug was partially fouled. Yes I don't understand why the timing was changed, only that it was. And that by changing the plug the issue was corrected. I replaced the plug with a Champion of the correct heat range, the same heat range as the NGK and what was recommended by Honda. Nothing was changed except the spark plug, same fuel, same ignition unit, same carburetor and air filter, even checked the flywheel key, was not sheared even slightly. It was more than one mower that did this and it was different owners. The first one to do this took quite a while to figure out as I blamed it on every thing except the spark plug.
I suggest you may have had a bad experience with counterfeit NGK plugs. They are "grey market" imported Amazon garbage mostly, but they find their way to small parts stores struggling to stay in business.
I have dealt with this in both small engine and automotive applications.
Most modern spark plugs are made with a resistor pellet inside the porcelain segment. The resistor has to be correct for the spark plug to work correctly.
One solution is to make sure you have genuine plugs or use non-resistor designs.
