Website slow
kbowley
For the past week or so I have had so many timeouts it drives me nuts. The dns is fine and tracert is fine with a couple of timeouts after 204.68.252.171 during an outage. That said, I believe this to be in your router (port forwarding) or hardware firewall, ssl/tls certificate, or the servers. Anyone else?
It called mot having enough bandwidth when you are trying to expand into other areas. They either got to pay more for more BW or stop expanding. Besides with all the ads they have they should have the funds.
I can't believe your hosting site, DigitalOcean, is unable to fix mesh and/or load balancing issues for such a long period of time. Your bandwidth is fine, extremely low load according to my testing. I was a CIO for a large company for years, and I would be calling DigitalOcean every 1/2 hour for a status and pushing to get it fixed. If they can't figure it out...get MS/Cisco in there to work on it with them. My test shows an MS server farm with a strong Linux-based security system in front of Cisco routing and switches.
I have been monitoring your network servers for an hour without issue. It is a database issue, IMO.
oops, spoke to soon....
getting 404 error
<!DOCTYPE html>
<html id="XF" lang="en-US" dir="LTR"
data-app="public"
data-template="error"
data-container-key=""
data-content-key=""
data-logged-in="false"
data-cookie-prefix="xf_"
class="has-no-js template-error"
data-run-jobs="">
<head>
<meta charset="utf-8" />
<meta http-equiv="X-UA-Compatible" content="IE=Edge" />
<meta name="viewport" content="width=device-width, initial-scale=1, viewport-fit=cover">
<title>Oops! We ran into some problems. | Lawn Mower Forum</title>
<meta property="og:site_name" content="Lawn Mower Forum" />
<meta property="og:type" content="website" />
<meta property="og:title" content="Oops! We ran into some problems." />
<meta property="twitter:title" content="Oops! We ran into some problems." />
lots of server time outs. I try not to come here because it can be so frustrating
They need to move the site to Bluehost, SiteGround, DreamHost, or HostGator...or in-house...this is unacceptable. I am not seeing any timeouts; DNS is fine, and Tracert is fine; the issue appears to be with JS or SQL or a combination.
another outage: Strange, it shows connection closed at Lightspeed hosting, but that is not their hosting site.
"x-frame-options": "SAMEORIGIN",
"x-content-type-options": "nosniff",
"last-modified": "Wed, 26 Mar 2025 20:48:01 GMT",
"expires": "Thu, 19 Nov 1981 08:52:00 GMT",
"cache-control": "private, no-cache, max-age=0",
"content-type": "text/html; charset=utf-8",
"set-cookie": [
"xf_csrf=t8mE6uND06hgKYQE; path=/; secure"
"date": "Wed, 26 Mar 2025 20:48:01 GMT",
"server": "LiteSpeed",
"alt-svc": "h3=\":443\"; ma=2592000, h3-29=\":443\"; ma=2592000, h3-Q050=\":443\"; ma=2592000, h3-Q046=\":443\"; ma=2592000, h3-Q043=\":443\"; ma=2592000, quic=\":443\"; ma=2592000; v=\"43,46\"",
"connection": "close"
