- Dec 7, 2022
- 2,252
Slomo-When you remove a head, you must lap the head and block area where the head sits. It's all in the prep. You don't clean the area and toss on a new gasket.
Every head I've pulled from 2hp to say 22hp, all were warped. 220, 400 and 800 grit on the garage door window. Let the paper do the work. No need to push hard while lapping. You will quickly see how warped it is.
Last a triple bolt torque regime should be followed. And after running once or twice retorque the bolts a few times. Only takes a minute.
I usually run a .002” feeler gauge under cylinder head to check for any warping with head on glass. How do you determine straightness?
7% leak down is very low with anything below 20% considered acceptable. If engine had higher hours on it and you opened it up, replacing the rings is the way to go. Also polishing the piston, and honing the cylinder and lapping the valves.
