Any One Have Experience with Cud Cadet Push Mowers
jimmys
Hi All, Looking to pick up a new gas push or self propelled mower.
I do have a Cub garden tractor that I really enjoy and wondered
how their push mowers are?
Thanks You
MTD now builds the Cub Cadet brand so anything you purchase with that name on it will not be of the quality you used to expect from them.
jimmys
Rivits I do recall hearing that somewheremguess I will forget about getting
a Cub Cadet push mower. Looks like a better make a choice between Toro
and Honda, Thanks
Scrubcadet10
Moderator
Staff member
'I'd go with Toro or Honda
Ozcub
deWalt are making a push mower with a Kohler engine , 21inch cut and either push or self propelled
When I saw the heading I thought he was going to buy a young cow , Cud Cadet
Oz
evh
I think Honda is getting out of the gas lawn mower business. So factor that into your decision.
Oddjob
I fixed a neighbor’s almost new Toro last year. To my amazement the engine was made in China. No name. But it was very similar to a Chinese made Kohler on an Ariens that I fixed a year before. The Ariens carb was dirty. A year later, the kid I gave the mower to brought it back. The carb looked clean but after another cleaning, the mower ran well. I recently saw a Taryl Fixes All video where he worked on a Cub Cadet that had a similar engine. He wasn’t a fan. I actually was impressed by the engineering on the China Kohler. Every fastener was a 10mm and easy to access. The carbs are easy to remove, which is good because in accordance with my experience and many others on the internet, they gunk up with regularity. The almost new Toro had an auto-choke that was stuck closed. Again, the design was elegantly simple. But the linkage needed some lube and the choke some exercise. The engines run smoothly…until the carb clogs up.
I think that Toro still makes a good mower and would recommend one if you are looking for a new walk behind mower, but buyer beware. Look for one with a Briggs, unless you like cleaning carbs.
I have two Honda’s. They are superb machines. But Honda stopped making gas mowers, so who knows how long parts will be available. Plus, the ones I have are top of the line and are heavy heavy heavy. I use my Toro much more than one of my Honda’s.
jimmys
Thanks for all your replies,appreciate it
kinard
I have both a Honda self propelled and a Toro self propelled. Without a doubt, the Toro is superior. Just can't wear them out.
