What model did I just buy?
Steve83
It has no ID plate on the frame, even though most of the factory labels are still on it. IDK what year or model it is to start looking for replacement parts. I've tried searching for "snapper zero 52 parts", but the only results I've found don't look like mine. Specifically: 2 pumps with 2 reservoirs, remote from 2 wheel motors with lots of high-pressure hoses.
I'm hoping someone can tell me at least the type based on these pics, to narrow down my search. I don't mind doing all the detailed searching, but right now I have no starting point since there's no model name/type sticker on it. Thanks for any help.
Tiger Small Engine
Take a flashlight and look everywhere on mower frame for model number. Do the same for engine. Without the correct model numbers you are shooting in the dark.
From my research is appears the model number tag for the mower should of been on that square plate on the side of the frame in his 3rd picture.
Probably one of these
NZM21520KWV
NZM21521KWV
Steve83
...look everywhere on mower frame...
I guess you missed the first sentence in my post. :rolleyes:
That's kinda what I said.
...the model number tag for the mower should of been on that square plate on the side of the frame...
I think so, too.
NZM21520KWV
NZM21521KWV
Thanks - it certainly looks like it's an NZM. (y) That's enough for me to find what I need.
Tiger Small Engine
I think so, too.
No, I did not miss your first sentence. You could not find model number and I gave you my suggestion.
Maybe if you washed it, might find the tag?
