Running on 1 cylinder
Dpak
Hello
Motor running on 1 piston have changed the coil packs and the spark plug and left hand piston still not working I have changed the coil packs from left to right along with the spark plug and legit hand piston still not firing any ideas.
Rocky J
Hello
If it is a Briggs you might also try unplugging both coils kill wires and try it again. Each wire has its own diode in it and they do go bad . It can have spark on both cylinders but one side at the wrong time / open ex valve piston on bottom of stroke .
Freddie21
Rocky has good idea and checking the valves is also good. Do a compression test on both cylinders and compare each.
Laabk2
Pull the plug on the left cylinder and make sure the piston is moving, had a twin on a JD that ran but seemed to have a miss. Everything checked out as far as firing and but still had a miss. Pulled the plug and found out the rod had broken.
Gord Baker
Hello
High tension lead from coil is likely faulty. Replace coil and wire. You should check compression first.
Freddie21
Bad wire, then the problem cylinder would follow the coil's placement. Coils were said to be replaced.
Dwstwrt
This may sound strange but I had a fellow bring me a Kubota zero turn mower with Briggs vertical twin that was only running on one cylinder as evidenced by using a laser thermometer on the exhaust Pipe. Working cylinder would hit 400 degrees in short order while non-working would hit barely 200 degrees. Long story short, after checking valves swapping coils from one side to other to no avail, cleaned the carb and problem was solved. Apparently, the carb has two circuits, one for each cylinder. Good Luck.
