Bwcland
- Dec 19, 2024
- Threads
- 1
- 5
Hello, my wife and I use FS131R and FS240R heavily on the property we live on and work on. Wife uses FS131R more often and machine needs help.
Machine purchased new few years ago and likely has couple thousand hours logged. Any advice or insight here great appreciated.
Could a bent drive shaft make the trimmer hard to start? The machine vibrates excessively when running. Have not changed the vibration damper insert part # 4180 791 9303 because the snap circlip inside needs a special snap ring length tool to get access in there I haven’t been able to find the tool yet to release the snap ring. I changed the rewind starter with a new replacement but did not help. Following the instructions at start with a short pull to coil then long pull the pull handle sticks and becomes hard to pull, too much for wife rips the handle out of her hands. When removing the rewind starter and rotate the starter cup by hand, notice it wobbles almost looks off center, and not rotate smooth. Could this mean bent drive shaft?
The second item is leaking fuel between carburetor and the engine is wet fuel. Hoses out of fuel tank look dry. The fuel line to engine part # 4180 141 8602 is wet. Can the gaskets wear with time and leak fuel?
Thank you.
Thank you.
