MalaiseMowerMan
- Jan 31, 2025
- 8
Hello, Apologies if this has been discussed but I can’t find it on a search. This is my first post. I live near Maleny Australia. Very high rainfalll over 4 meters/year. My block is not large, only about one acre but has several steep sections including a hill of 15-17 degrees and a ditch of over 30 degrees. So far I have only mowed it with a self-propelled Honda but as I get older I am finding this increasingly difficult.
i just bought a Cub Cadet ZTS1 42 in. At my first mow I could do most of the block without any problems. I didn’t attempt the 30 degree section. I managed to do the 15-17 degree hill with difficulty. As instructed I mowed across the hill and turned upwards but it felt a bit slippery in parts and the inside front wheel was lifting slightly on some turns.
i understand why turning downhill is not recommended for conventional zero turns where the front wheels are completely passive, but does this also apply for ZTS mowers with front wheel steering? Although I am a newbie at this, it actually felt safer turning downhill than uphill. It seems to me that with uphill turns the front wheels are already above the back and lift quite easily. I would be most grateful for the recommendations of experienced ZTS owners/users.
Regards, M
Regards, M
