Tiger Small Engine
- Dec 7, 2022
- Threads
- 3
- 1,660
$367.00 for a 12oz can @Home Depot.
$20 per can on Amazon for Slip Plate, which is a spray on graphite. The point is, that mowing dry grass is the key. When you have to mow wet then scrape deck with paint scraper. Many decks that come in for tune ups are absolutely packed with grass. I have never used any products that are applied to underneath the deck to prevent buildup. It is a temporary solution at best.
Any good leaf blower will blow more than an air compressor air gun. You can blow your mower off all the time, however, some mower designs simply gather more debris under the engine shroud than others. Ideally, remove engine shroud once a year and check and clean. I see several engines each year that are close to overheating each year once engine shroud is removed and cooling fins are cleaned.
