BR 600
7474
Hello,
BR 600 blower that will run at full throttle for 15 minutes and then stall out. This has happened with the fuel cap on and with the fuel cap off.
Have done the following…..
New Spark plug
New Air filter
New tank vent
Valves adjusted
Spark arrestor cleaned
Thanks for any assistance.
Ignition module warming up and loosing spark. May need to check for spark after it stalls
7474
Starts right up after stalling. Needs a prime first but then starts right up.
When was the last time the fuel filter was changed. Also there is a second filter screen inside the fuel inlet side of the carb that will collect debris
Alan46
That’s exactly what happened to me, it was the filter screen. I check it every so often!
7474
Never.
Visual inspection of filter closet to filler/gas cap looks clean.
Will check the one by carb.
Will replace both in tank and see where that takes me.
7474
Cautiously optimistic, for those keeping score at home, tank fuel filters for the win!
Just ran about 30 minutes full throttle no issues.
