Douglas Lee
- Sep 5, 2024
- 97
Thanks to all for the feedback on the starter assist modification.
Doug Lee
Doug Lee
The people of America have spoken.Our crystal balls have become very cloudy, due to the recent elections. You are not giving us much info to help you. We have no idea how old this unit is, which engine it has, or if you have done anything to solve the problem besides changing the relay? With out unit model and serial numbers, plus all engine numbers everyone here will just be guessing. My first guess is that there Is a loose or dirty connection. My second guess is that you don’t have the proper size battery. If it is a single cylinder engine, the battery should have a minimum of 300 CCA. If you have a twin, the battery should have a minimum of 350 CCA. If you want more help please provide more info.
The American people have spoken.Our crystal balls have become very cloudy, due to the recent elections. You are not giving us much info to help you. We have no idea how old this unit is, which engine it has, or if you have done anything to solve the problem besides changing the relay? With out unit model and serial numbers, plus all engine numbers everyone here will just be guessing. My first guess is that there Is a loose or dirty connection. My second guess is that you don’t have the proper size battery. If it is a single cylinder engine, the battery should have a minimum of 300 CCA. If you have a twin, the battery should have a minimum of 350 CCA. If you want more help please provide more info.
Since day one, when endeavoring to start the mower, on first try I get only a click, and on second try turns over and starts immediately. I installed a relay per the dealers instructions, but nothing changed.
Any thoughts on how to correct this would be greatly appreciated.
I have recently removed the relay (was wired as in Star Tech's diagram), gave the ground wires a good cleaning and unit appears to start better, (just not consistently) at this point and time.Where did you add the relay- show photos and a diagram. Is it activated by the crank wire and bypassing that wire, with tab 87 connected to the battery and tab 30 connected to the solenoid?
Adding a relay strikes me as similar to adding a fuel filter when the original one becomes clogged.
Has anyone ever lubricated the Bendix on the starter?
