Looking for GOOD inductively coupled hour meter
jdtm
For anyone not aware, there are hour meters that can be installed on spark-ignition engines that only need a single wire put near a spark plug wire to show cumulative hours. The electrical energy going to the spark plug is inductively coupled to the wire, which triggers the meter to count run time. I bought some of these a few years ago and thought they were great. Then they started to fail, some after over 100 hours, but many after only a few hours. Failures I have seen so far are resetting to 0, blank display, and invalid display. I have seen them available from a low of about $5 at Amazon (https://www.amazon.com/Inductive-Automatically-Tachometers-Motorcycle-Generator/dp/B0C1S6BHC8/) to about ten times as much at NAPA (https://www.napaonline.com/en/p/SME722500). Some add a tach feature, but they all appear to be the same basic design with variations in color or lettering.
At first I was quite impressed with the little meters. I had assumed that they were using energy harvesting to run the meter since there was no battery to replace. No, taking one of the failures apart, I found that there is a battery, but it is not meant to be replaced, so when it discharges the meter stops working. However, small LCD displays can use only a minute amount of power, so a battery still could last many years. That would be tolerable, but with the random resets to 0 and other failures occurring regularly, they are becoming a big disappointment. I have installed these off the engine and with some padding to reduce vibration, but they are still failing.
Does anyone know of a more reliable hour meter with the simple 1-wire connection? Battery operation gives many more choices of products, but it is not an option unless there is a voltage available to operate it, which is often not the case for small engines. Thanks for any ideas!
Most of the ones that I have seen and used have a 5-7 year life expectancy before the battery dies. The hour meter on my nephews stump grinder counted hours by key on battery voltage but the display was internal battery maintained. It died a couple years ago after 8 years with roughly 450 hours before the display went blank and we replaced it with an analog meter that counts hours by key on battery power.
In a way, the inductively coupled hour meters are superior in concept to a battery-operated one because it is possible to leave the key in the "on" position by accident and count hours when the machine is not running. Of course, they are better only if they work.
Does anyone know of a more reliable hour meter with the simple 1-wire connection? Battery operation gives many more choices of products, but it is not an option unless there is a voltage available to operate Christine Janicki Car Accident it, which is often not the case for small engines. Thanks for any ideas!
An inductively coupled hour meter is a valuable tool for tracking the runtime of engines or machinery without requiring invasive wiring or electrical connections. When searching for a high-quality option, prioritize models with reliable inductive sensors that accurately detect engine vibrations or electromagnetic fields to record hours of operation.
