How does one repair/replace a leaking fuel bowl drain on a LB 5239 G mower?
franchi
  • / How does one repair/replace a leaking fuel bowl drain on a LB 5239 G mower?
I need some help on the above problem.
Tia,
Franch
franchi
The bowl drain is small spring loaded plunger on the bottom of carb. By pressing on this plunger, water and dirt can be drained from the bowl.
I bought a repair kit for this drain and all that I received was a 3/32” dia. piece of paper to replace the one on the end of the plunger. How is this done?
The plunger may be removed by removing a brass retainer and a spring but I was not smart enough how to do this. It was like a Chinese puzzle!
Tia,
Franch
TIa.
Franchi
franchi
Tia,
Franch
Hi Rivets:
Thanks for the reply!
The thing that is leaking is called dump valve assembly.
The 5239 carbs I’ve looked at use a plastic carb bottom. You have have a metal Tecumseh carb. To remove this drain you must hold the bottom of the bowl so you can hold the drain in place with your finger. With a finger on your other hand push up on the retainer depressing the spring. When you do this you will that the retainer has a slot and larger hole. Push the retainer over to the large hole and it should pop off.
