Replace coil old poulan blower
1967
Long shot, pictures to big to upload.
Old blower, pbv200le 711848. Believe it's type 1.
No spark, want to replace coil. Taken all apart down to removing nut on top of pull cord assembly casing . This is connected to crankshaft. How do I go about it? Is it a puller? Cord in plug hole to stop piston from moving and go counter clock wise? 1/2 in socket fit on it.
Don't want to break anything....
Thanks in advance .
1967
Made mistake in original post. It's 11/16 socket that fits.
Are you referring to this one?
If so it just slides off and on.
No way to text here.
1967
I know, wasn't thinking. Saw that part chart, but don't seem to show the piece I'm talking about. Will see if can get app to compress picture/ change settings and get back to y'all.
Thanks.
Just think how I feel that it seems everybody is demanding my cell number which I can't because I have no cell phone beside they don't work very here anyways. Even with a tower in sight my customers can't use their phones here.
1967
All good, will find a way.
1967
IMG_20241031_115125736_HDR~2.jpgthats the part on top. Need to remove it to access coil and flywheel.
1967
Looks like it's bolted to the crankshaft. Top treads is where the fan blade is attach.
